forgot my security question answer
macrimariap
...and now I can't login to update the payment method after I lost my debit. help?
7 REPLIES 7
@Kishanan_13 wrote:
I forgot my security questions password
@Kishanan_13
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck....
Kishanan_13
popping
@macrimariap wrote:
it is asking me to login in order to submit a ticket which I cant
@macrimariap
Create a moderator support ticket for help using this link https://publicmobile.ca.ada.support/chat/
Tell SIMon what is the issue (important) - Use "forget password and answer to security question"  SIMon will show you Contact us button for you to create support ticket.
1.  You can provide your PIN# instead of login
2.  Don't know your pin?--provide any 3 of the following:
- Complete mailing address,
- Email address,
- Alternate phone number,
- Date of birth,
- Last top up date & amount
Dunkman
@macrimariap
If you are having difficulties submitting a ticket for moderator help,
Send a private message to moderator through the following link :
You can use your account PIN instead.
macrimariap
gpixel
@macrimariap contact customer support mods
click on the question mark chat bubble to the bottom right of your screen
type "locked out of self serve"
(use the chat bubble options, then click "submit a ticket, click me" option)
make sure to check your inbox(top right corner envelope icon) periodically, for a response
*you need to login using your community account
