Reply
syg
forget my 4 digit pin what should i do ?
i already send a msg to a @Moderator_Team over 3 hours ago but no replly
Re: forget my 4 digit pin what should i do ?
Hey, so it usually does take about 48hrs for the moderator to reply but when they do, have the following info available and they should be able to help you out immediately!
Provide 3 elements of the following information: Date of Birth, Address with Postal Code, Home or business contact number, Commonly called numbers or text messages (SMS), Last top-up amount and the date, the Last booster purchased and the date or Email address.
Hope this helps!
syg
@SimonM21
i wos thinking that it normel 2-4 hour for @Moderator_Team to replly
you say that take 48 hour, its very bed, i think for this kind of service to switch to another campany like fizz, my freind say that hi use fizz, hi chat with tham for a waiting about 5 m
syg
if i will not her back from @Moderator_Team till tommorow i will switch to fizz
syg
@mod please i need my 4 digit pin
@Moderator_Team please i need my 4 digit pin
syg
Well, for me it took about 24-48hrs for them to respond but once they get to you, everything will happen really fast!
I guess, you also should take into account the fact that there are probably hundreds or thousands of people messaging them regularly so they have a lot on their plate! Initially I was upset too but I think I get where the @Moderator_Team is coming from! But thats my opinion tho!
syg
@Moderator_Teamplease i need my 4 digit pin
syg
syg
