Reply
Highlighted
e-mail address and password UNKNOWN. Can't access
I am bogged down trying to get registered in self serve.  First question asked is e-mail address and password.  Do not know either because the tech who signed me up did not write them down for me.  How do I change them both so I can get 3 big issues fixed with Public Mobile.  I am so frustrated I feel like I should just cancel and start a new plan with a provider that actually helps their users when things go really wrong, as it has in my case.
Highlighted
Re: e-mail address and password UNKNOWN. Can't access
@LHildebrant   Do you have more than one email address, then check through all of them to see if there was an email message sent there from PM.
Otherwise the only way to change emails/passwords is to submit a ticket to moderators via SIMon chatbot ? mark bottom right of your screen or private message Moderator_Team via this link:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Highlighted
@LHildebrant , were you asked for an email address during account setup?  If your email was used, you should have received a welcome email.  As already suggested, you can contact the moderator team for assistance if you are stuck.
Highlighted
@LHildebrant
Did you by any chance get the printout for activation. If not you should contact moderators and they will reset it for you
If yes you can actually use that email to register your selfserve even if it's mispelled as you will not need to receive any confirmation at that email address, but you will need to receive an SMS. After you register your selfserve you should contact moderators to change it to the appropriate email
Highlighted
If you activated at store, your self serve account shouldn't have been created.  If it was never set up, there is no password. That's for your to choose. There is a secuirty code that needs to be sent to you in a text message.
