02-04-2017 07:24 AM - edited 01-04-2022 01:28 PM
Hi,
I always, every single time, want my phone to forward to my home phone when:
- busy
- no answer
- whatever else
I've noticed some prepaid providers (telcel in Mexico), won't let you use standard GSM features to update your 'call no answer' 'call unavailable' to point away from voicemail.
What happens with Public Mobile in this case? Can I forward ALL unanswered calls, NO MATTER WHAT to my home phone?
Thanks!
02-05-2017 05:37 PM
02-05-2017 10:49 AM
I used these codes to set up call forwarding / not available about a month ago. Works well never have to worry about settings on the phone itself.
http://www.geckobeach.com/cellular/secrets/gsmcodes.php
Just be very careful about which one you enable. You can always undo it but you don't want undesirable results.
02-04-2017 02:38 PM
Hmm.
Well, thanks to both of you... my biggest worry, call forwarding (and therefore not using voicemail on the phone) is over.
I'm guessing 'no' to call forwarding minute limitation.. but, I'd hate to run into it after a number port. Seems like I can port at any time, so maybe I'll do a 10 day test.
02-04-2017 11:44 AM
02-04-2017 09:50 AM
Call forwarding can be managed using the phone dialer settings. It's pretty simple. I don't think there's a fee for the service. I assume the forward number is not a long distance number.
02-04-2017 07:30 AM
Might as well ask a couple of other, related things:
1) Some providers charge for 'call forwarding minutes'. Yes, silly as that sounds, I've run into it. Fido around 2010, and others.
What about PM? Is call forwarding UNLIMITED, without any per minute charges?
NOTE: sometimes it SEEMS unlimited. But, I live waaay out in the country. No cell phone has service here. Yes, none. This is why I want my cell to:
- forward to my home phone, no matter what when I don't answer, etc
- not pay call forward minutes. Rogers, at one point, had 1000 call forwarding minutes. This was not nearly enough in some cases... as customers sometimes will call my cell number, and a tech support call can take time.
2) Can I change the number of rings, using standard GSM features, prior to forward?
3) is there an email to text gateway? EG <number>@pm.ca = SMS message.
I know of alternative ways, but this costs me extra (for server paging, etc). No, I don't want to use email, I want to use SMS for that.
Thanks!
