can't change plan
zakisp
I'm trying to change plan (upgrade)
trying to do this since 3 hours i can't
the button are deactivated so i need to cancel next billing but when i click nothing happen
An other thing that frustrate me with public mobile is that Wifi Hotspot (Tethering to other device) is not working, but when i use other company SIM it work for the same phone
I tried all solution adding the dun,   it did not worked, and i did it carefully (i understand how it works) is it blocked by Public Mobile ?
popping
@zakisp wrote:
I cleared cache, i still don't work, i see in chrome, there is some javascript code that is blocked
anyway it work fine for me now on mozilla
@Anonymous
2n issue (which i may need to submit a different post about it in different forum
I wanted to connect my phone data to my pc cause sometimes i go out and i want to connect my pc using my phone data, it doesnt work on public mobile and i never worked for me since almost one year. when i plug chatr sim card it work fine
Yes i'm aware of the french forum, i guess this one is more active
I don't know about PC.  It must have setting similar to APN settings on your phone.
You can enable wifi hotspot on your phone and connect your PC using wifi.
zakisp
@Anonymous
@zakisp wrote:
it's wierd it work on Mozilla firefox and not in chrome
I tried again in both browser it works again well on mozilla....... and not in chrome
Do you have any filters and add-ons in Chrome? That is weird because Chrome is a suggested browser.
zakisp
Maybe clear cache/site cookies, or different browser or incognito/privacy mode.
Do you mean using your phone as the hotspot for other devices to connect to? Or do you mean connecting to a hotspot with your phone?
Hotspot works fine here.
Do you know there's a whole French side to this forum?
