Reply
Highlighted
add-ons
I have added the add-ons US Roaming - Talk Text 250 Data (10-day) twice but I can't seem to activate it....help.
Highlighted
Re: add-ons
@GlennK  did you add the funds to the account and then go in add ons and purchase it?
Highlighted
Re: add-ons
You can only buy it once which makes me think that you probably withdrew money ( twice) for it but didn't go ahead and purchased it.  You have to go to https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/?PageRedirect=Redi... to pouches it
Thanks
Highlighted
Re: add-ons
Do you see the add-on in your overview page under 'My Data and Add-Ons' when you log into your account?
Also if you are already in the US have you enabled data and roaming on your phone?
Try rebooting your phone, and manually connect to either AT&T or T-Mobile if your phone doesn't automatically select one.
Highlighted
Re: add-ons
Hopefully, you're in US because the 10 Day US Roaming add-on will only work whilst in America.
Log into My Account...do you have the value of the add-on sitting in Available Funds ?
Highlighted
Moderator
Re: add-ons
Hi GlennK,
Should you still need assistance regarding your US roaming add-on,  we will gladly examine the matter, should you create a ticket via SIMon. Here is how to: Click on the following link: https://www.publicmobile.ca/en/bc/get-help > then click on Chat with SIMon > ask to contact a moderator, and follow the required steps.
Yours,
The Public Mobile Moderator Team
