Where to see text message count for $10 50mins/50 text plan - with 400min addon
cphav_105
Hi
On many of my family accounts, I cannot seem to find where to see my "outgoing text message" count.  I have seen it on some people screen capture but on our accounts the text message count is replaced with the minutes addon usage details.
Anyone know fix for this, so far whenever a family ask how many text are left, I have to go through the logs and count them.
12 REPLIES 12
Anything that is not unlimited, will be automatically removed from that usage list, upon full consumption of the service.
This how LD minutes, Data Blocks (base plan), data add-ons, and roaming buckets are managed also.
@cphav_105 wrote:
This disappearing entry, do you know if it applies to the minutes as well?
All the items in that list will disappear when consumed. Think of the $10 plan as being like an add-on.
cphav_105
will13am
cphav_105
Okay thanks, will verify this once the account cycles which should be tomorrow.  Thanks to everyone for chiming in.
cphav_105
It appears that depending when you signed up to the plan, the display is different.  I checked on 3 family accounts and only the first account signed up had the issue.  The other 2 were fine.  The first being the one that signed up when the plan was first released.
srlawren
When it disappears from the Overview page, that means you have used up all 50 for your currnet plan cycle and have none left.
Dunkgirl
@cphav_105 wrote:
Hi
Werid I can see it in my data/add on section
cphav_105
cphav_105
I would but the website is freezing when i try to sign in.  However checked on another account and it appears to show correctly now.  It was about 3 or 4 days ago where I had to count.
Will verify the other accounts when I am able to log in.
RobertQc
@cphav_105 wrote:
Hi
When you log into self serve overview it should be there under add-ons, can you post a screen shot?(but remove personal details) ?
@cphav_105 wrote:
Hi
I just changed over and it all shows down in the Add-On area in Overview.
