12-26-2019 01:49 PM - edited 01-05-2022 08:43 AM
12-26-2019 04:18 PM
After logging in to self serve, the referral code is in the top right corner, in green. Give code to anyone you like.
12-26-2019 03:42 PM
To refer a friend:
1) Login to your Self Serve account
2) On the right side of the screen, there is a referral code and link you can send to your friend so they can sign up.
12-26-2019 02:46 PM - edited 12-26-2019 04:02 PM
Get your referral code here and give it to your friend.
They need to go to http://activate.publicmobile.ca to activate their sim card and create their account. During that process your referral code goes here:
12-26-2019 01:54 PM
@Super_sharp007 Access your selfserve account. Get your code from the top right area of the landing page. Give that code or copy the link and give it to your friend.
12-26-2019 01:53 PM
@Super_sharp007 log in to your self serve account and look on the right top of the page and you'll see your refferal code and also a link that you can send to your friend to activate with your refferal code already in the box
12-26-2019 01:52 PM - edited 12-26-2019 01:53 PM
Your friend will supply a referance number and when you activate the PM sim...it'll ask for that number.
