Reply
Highlighted
Unlocking phone
I need to unlock phone
Tags (1)
Accepted Solutions
Highlighted
Re: Unlocking phone
@JaysonM
If it is a Public Mobile branded phone, unfortunately that belongs to a previous iteration of Public Mobile that no longer exists. You can contact the moderators with the IMEI number and see if they will give you an unlock code. However it can take them up to 48 hours to get back to you, due to the age of the phones, those codes can be obtained nearly free from online or corner cell phone repair shops. I would recommend the later option if time is of the essence.
All Replies
Highlighted
Re: Unlocking phone
Hi! As much as I know, unlocking the phone is now free. You will need to call the phone compagnie's custumer service to get your device unlocked. I unlocked my phone with virgin this way!
Highlighted
Re: Unlocking phone
Did you switch from another provider ? Or do you have a Samsung phone ?  If it is locked to your previous then you would need to contact them.  If it is a Samsung phone then you would need to cotact them.
If you entered in the SIM code to many times you will need to contact the moderators, you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
If you just put your SIM in and it's saying it's locked then it's locked to your previous provider and you will need to contact them to unlock your phone.
Highlighted
Re: Unlocking phone
@JaysonM
1. You can get your phone unlocked by the provider who sold you your phone.
2.  For iPhone, you can get it at Apple store.
3.  For Samsung phones, you can contact Samsung Canada to get it unlocked.
Highlighted
Re: Unlocking phone
It’s a public mobile phone
Highlighted
Re: Unlocking phone
@JaysonM
Highlighted
Re: Unlocking phone
@GinYVR Telus bought PM as a continuing business so I believe that they carry the obligation to unlock for free and would have to have the ability to do so.
