08-04-2019 10:17 PM - edited 01-05-2022 06:16 AM
Hi unable to purchase add on for US roaming. My credit card not going through.
08-14-2019 07:34 PM - edited 08-14-2019 07:48 PM
@ElsaFilice Please don't post personal information on a public forum. Use the 3 dots top right of your post and delete all the personal info.
As for international calling, log into your self-serve account and click on plans/add-ons, from there you should be able to purchase the add-on that you need. There are two options, $8 (edit: not $10) for 200 mins that can be used for calling US and in Canada. Then there is the international option of adding 400 mins for $15. This will allow you to call the 16 countries listed there.
Also remember, you need to first add funds into your account (either CC/voucher) before making the add-on purchase.
Edit: Just saw it is $8 as per @hairbag1 edit, thanks, hairbag1
08-14-2019 07:31 PM - edited 08-14-2019 07:32 PM
@ElsaFilice hi you are on a public forum don,t give away your private info so easy click the the 3 dots top right corner and edit your post
08-14-2019 07:28 PM - edited 08-14-2019 07:36 PM
You have the option of buying the $8 / 200 minutes of Canada & US calling ...or the $15 / 400 minutes of Canada & International calling (including US) calling. Both of those add-ons work for calls whilst you're in Canada only.
08-14-2019 07:22 PM - last edited on 08-14-2019 07:43 PM by Luddite
Need to add $10 international calls to cell number ========= belonging to Angelo Pisani ===========
08-05-2019 03:49 AM
@Unwana wrote:Hi unable to purchase add on for US roaming. My credit card not going through.
If in a hurry to pay and but add-on, buy voucher from a store or recharge.com. After trip, then try to figure out.
08-04-2019 10:29 PM
@Unwana If the cc on file is not going through then more than likely you will also have problems during renewal. As a temp fix you can use a voucher for the addon but you should contact the moderator to check you cc on file.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
