Reply
Highlighted
Unable to make or receive calls
I am unable to make or receive calls on plubic mobile phone
Tags (2)
Highlighted
Re: Unable to make or receive calls
did you just port your number? it may wait few hours to transfer from your provider.
Highlighted
No, I have had this number for sometime now with Public Mobile
Highlighted
Try the lost phone trick to reset your account.
To report your phone stolen.  Login to your account.  Choose Plans and Add-onstab. Then choose Lost/Stolen Phone tab.  The choose Suspend Service tab.  Logout.  Wait few minutes.  Login in and report your phone found.  if you still have problems then try contacting a moderator.
Moderator can be reached at
Highlighted
@kejWHen you dial *611 from your phone what happens?
Highlighted
It tells me about my account. Like my avaliable funds and if I want make a payment etc.
Highlighted
@kej  That means you account is active. So when you try to make a call to you get an error message?
Edit: Are you on a limited minute call plan or unlimited?
Highlighted
If you had a working account that suddenly stopped working.. .and you have tried your SIM in a different phone, I would message a MOD for help.
Also - just make sure ur billing is up to date.
Highlighted
@geopublic  I have not used all my minutes. The account is fine.
thanks for your help.
Highlighted
@TheOldVR  I will try that.  Thanks
