Try to reset my password
dingtianlidi
hey there,
I have tried to login self serve, but I forgot my password. Following the instruction, I provide my email address to reset the password, and was told I had been locked out and I need to contact Public Mobile for help. So I'm here...hope anyone can help me out. Thank you
7 REPLIES 7
@keepasa wrote:
Its seems after several failed attempts, the system will lock your account which is what likely happened.  Only option now is contacting the moderator for support.  I'm wondering if after a 24-48 hours the account gets unlocked and and accept a reset PW request.  But anyway better to contact support so they can reset it for you.  Good luck!
@keepasa   Yes, the lock is only 1 hour , at least the first time.  I forgot if it will trigger a longer lock if it is locked again.
@keepasa    Correct that after too many attempts with incorrect login information the account gets locked, however, you can usually retry again after an hour.
Edit:  Additionally it would probably be a good idea to also clear your cache/cookies and use another browser before retrying after the session lock.
keepasa
@dingtianlidi wrote:
Thank you.Happy Thanksgiving!
@dingtianlidi
your welcome dear Happy Thanksgiving...enjoy your day.
@dingtianlidi   To reset My Account password, use the Chatbot to open ticket with PM, you can do this to get to ticket opening quicker:
type: Forgot log in information
Click "Contact Us"
Click "Click here to submit a ticket"
dingtianlidi
@dingtianlidi
you can try Forgot your password visit Here link, and enter your email address,
or you can Contact Customer Support Agent by  ,and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to CSA,Click Here link,
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck..
