05-13-2019 06:27 PM - edited 01-05-2022 04:55 AM
Can I transfer my number from koodo to Public Mobile and how to do it thanks Grant
Edit by SD08: Message moved to its own topic and title changed
05-13-2019 06:53 PM - edited 05-13-2019 07:07 PM
I've moved your post to its own topic. In future, it's best to start your own topic for help, for better visibility.
If you don't have a PM account yet, I recommend that you first activate your PM account and plan with a temporary number from PM, then port your number from Koodo afterward.
If you are on a Koodo postpaid account, you can port a number yourself, by going into your PM self-serve. Go to Plan & Add-ons -> Change Phone Number, and select Transfer a wireless or wireline number from another provider. Be sure to enter the Koodo account number exactly as it appears in your Koodo account.
If you are porting a number from Koodo prepaid, you will require moderator assistance. Click here to send your request by private message to the Moderator Team.
05-13-2019 06:28 PM - edited 05-13-2019 06:30 PM
@grantstewart306 wrote:Can I transfer my number from koodo to Public Mobile and how to do it thanks Grant
Yes you can do it by yourself if you are a customer but you are not in the good place to ask that...go here...https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/getting_started
