Self serve password reset
Abelanger
I keep getting the email and resetting the password but when I go back to login it fails...help
Jackhyf63
@Abelanger To reset the password, you will need to send a private message to the Moderator_Team with your account info. They will get back to you soon.
sandpublic
It could also be your browser, try clearing the cache or using another browser or icognito mode. Also check this article for more info:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Community-and-Self-Serve-Accounts/ta-p...
Dunkman
@Abelanger
If the password reset funciton is not working for you, you will need to contact moderator.
Send a private message to moderator through the following link :
