Self serve errors
canucks4life
Seems to be quite temperamental at the moment...anyone else?
16 REPLIES 16
SD08
Excellent.  Thanks for the update @Jeremy_M.
I just tried it and it seems to be working normally now.  Robot Happy
Jeremy_M
Retraité / Retired
Retraité / Retired
Hey folks,
We were experiencing some technical issues earlier this afternoon with Self Serve. The issue was causing latency/lag when a customer was trying to login or use the functionality within their Self Serve account.
Our teams were able to resolve the issue around 6 pm Est, and everything should be back to normal.
Please advise me if you're still experiencing issues with Self Serve, including latency.
Thanks,
Jeremy
Self-serve is a bit slow right now but everythign is loading without any error.
canucks4life
*611 is probably easier.
Check my earlier reply I also add a link how to connect with mod Dept
** I am not a Mod, please do not include any private info in a private message to me.**
TechFreakDad
How do I know who a mod is?
If you need a data and you can't login then Send a msg to mod they will look after you but before sending a msg try different browser and also try forgot password option if that doesn't help then send a msg to mod
Send any one of them a private message by  clicking on the link( http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
with your phone number  username and an explanation. Coverage is currently: Mon-Thursday 9am(EST) to 9pm(EST) and Friday, Saturday, and Sunday from 9am(EST) to 5:30pm(EST
TechFreakDad
me no able log in at all. me need data add-on urgently
@SD08 wrote:
@will13am wrote:
Come on folks, lets not overstress what is held together with spit, glue and chewing gum.  Cat Tongue
@will13am
Don't forget duct tape.  That fixes everything.  Robot tongue
@SD08, I thought about include duct tape as well.  But then things would not be so fragile.
SD08
@will13am
will13am
it takes a while for me to log in, but everything works fine
SD08
I should add that the Plans and Add-ons page was the one page that returned an error when loading.
Canuck
Plan change page is errored for me,just when I needed it too. @MarieHelene_L @Shazia_K
SD08
@canucks4life
It just took me about a half minute to log in.  After I got in, some pages worked fine, but others were laggy.  Using Firefox on WIN7.
Samianauman
Mines was kinda legging few days ago but seems pretty normal now
