Self-Serve Just Keeps Refreshing - Can't Login
Bonbu
I can't login to my Public Mobile account at all. I've tried on different browsers, on different devices but nothing works. Each time I login with my credentials the login page just refreshes. Nothing happens. No dialogue appears or anything. This is beyond frustrating. Does anyone know how to fix this?
gpixel
@Bonbu if you have any adblockers try disabling them
@Bonbu  No issues at my end.
As suggested by @HALIMACS  clear your internet history and cache. Try. Also try in incognito mode.
Not sure what you need from your account but you can hear some stuff by calling 611.
HALIMACS
Hi @Bonbu
Try clearing cookies and cache.
Wait 30 minutes.
Then open incognito mode tab and try again.
EDIT:   Also, just checked my login, it worked.   So not a system-wide problem.
DDM69
Try using Simon the chatbot and ask for a moderator to help you. Someone will find a solution for you and welcome to Public 😁2021-01-05 18_06_47-Self-Serve Just Keeps Refreshing - Can't Login - Community.png
