06-02-2019 09:28 PM - edited 01-05-2022 05:12 AM
06-02-2019 09:34 PM - edited 06-02-2019 09:35 PM
@Annajcs2019 Reboot your phone with the SIM installed. Tell us the exact message that appears on your phone.
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
06-02-2019 09:30 PM
More details would be helpful....
Are you a new customer putting a newly activated SIM card to your phone? Your phone might be locked to your previous carrier. If so, you will need to contact your previous carrier for unlock code.
06-02-2019 09:30 PM
@Annajcs2019 a écrit :My SIM card is locked
If you need a puk code for your sim card only the moderator can help you with that click here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and ask them. Be patient waiting time is few hours to 2 days.
