SIM ACTIVATION NOT WORKING
theblacklabel31
27 REPLIES 27
Seems the mods take the easy way and just clear the whole post rather than the careful editing that the Oracles do. Sigh. (assuming the OP didn't) Thanks for what you do Oracles.
@theblacklabel31
I'm happy to hear you are up and running. May I suggest you log into your account and change your password just to be safe. Thank you for removing your personal info. Only communicate that info with a moderator thru private messaging after you have contacted them.
theblacklabel31
working now thanks
@theblacklabel31
Do you see public mobile?
 @theblacklabel31 : Your contacts are likely on the other phone. You would need to copy them over. There are many ways to do that and I don't know how technically inclined you are.
@CS_Agent please remove personal information
@NDesai @mimmo @Luddite @ShawnC13 , @will13am,
@popping@Dunkman@Lieux , @computergeek541
Please remove personal info on 2 posts
theblacklabel31
now when I put the sim on the android phone it no lock screen then I see a 3g signal on top on the phone upper right but when I check the contacts I don't see any numbers
@theblacklabel31
Please edit out your personal info by going to the three dots top right corner of your post.
@Dunkman @computergeek541
Help please and thank you.
 @theblacklabel31 :
So here's the method
1. buy SIM
2. activate it
3. pay for a plan during that
4. have compatible, unlocked phone
4. insert SIM
5. restart phone
If phone not unlocked, ask previous provider.
If phone not compatible, get a different phone.
Again...what make/model/submodel phone do you have the Public Mobile SIM in?
@theblacklabel31
Is this the screen message you are getting?
theblacklabel31
@theblacklabel31 you bought a sim card for $10. That's all.  You don't have a Public Mobile service yet.
You have to activate that sim card.
go here Activation Portal to activate the sim card.  Choose a plan here.  Pay for your plan. Complete the 4 steps of activation.
RosieR
theblacklabel31
its has $10 when I login the first time I put $10 it was successful
wifi number was a TextMe app
form the previous provider it was not unlocked yet.
my previous was LG but it did not work now I'm using a android phone not LG
@theblacklabel31 wrote:
1. have you gone through activate.publicmobile.ca
2. have you successfully paid
3. did you transfer your number from another provider
4. what make/model/submodel is the phone
5. is it unlocked from a previous provider
1. yes. I did.
2. yes $10
3. NO. its a new number but when I first put the sim card on the other device it has a wifi number it was an LG phone
4. now I just put the sim on the new phone its an android phone
5. No. but I only got 1 more try then its gonna get locked it is already 9 times that I try to log in.
@theblacklabel31     Are you trying to change SIMs for an existing account?  If you are that can only be done by moderators for now.  You'll need to submit a ticket via chatbot and follow prompts here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
 @theblacklabel31 : Ok we have some answers. Apparently I could have been clearer.
Was the payment for the plan successful? The $10 was likely for the SIM alone.
What do you mean "wifi number"? Maybe doesn't matter as you said it's a new number.
By locked I meant is the phone unlocked from a previous provider? That 10 count thing sounds like needing to put in an unlock code. You need to get that from a previous provider.
LG what? Just the phone that you wish to use with the Public Mobile SIM.
theblacklabel31
1. yes. I did.
2. yes $10
 @theblacklabel31
1.
2.
3.
4.
5.
theblacklabel31
i says no sim
 @theblacklabel31 : Please fully describe what all you have done. It's rather hard for us to read your mind over these short sentences of very little information. Have you read the prior replies in this thread? Answer the questions or follow the suggestions.
Try translate.google.ca if there's a language matter.
theblacklabel31
not working still I put it on a new phone send me activation
HALIMACS
@theblacklabel31
If you need help with activating, you can get live activation assistance during regular business hours here:
https://chat.telus.com/chat/publicmobile/chat-pm.html?portal=publicmobile&language=en
I CANT GET MY SIM ACCTIVATION
@theblacklabel31 ,
If you are trying to activate a new SIM card/account, and you received an invalid SIM error, and your credit card was not charged, than after waiting 50 minutes for another attempt, make sure to:
  • clear your browser's cache or try a different browser
  • open a tab in incognito mode to complete the activation
IF you did complete the SIM activation, and your credit card was charged, and you are receiving a SIM error message,
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
*is your PHONE LOCKED?
Contact your previous provider to unlock it for you.
You will need your imei number, dial *#06# to get it.
Are you someone trying to become a new customer or are you trying replace your existing Public Mobile SIM card?
@theblacklabel31
If you have attempted to activate you must wait out the the 50 min session lock before you try again or you will get an error message when you enter the sim number again.
@theblacklabel31 What happens when you go to https://activate.publicmobile.ca/? Enter your sim card and proceed with providing other info?
theblacklabel31
NDesai
@theblacklabel31 Can you describe what exactly is not working? Are you getting any error when you try to activate?
