Reply
Highlighted
Re: Resetting password
@Luckman wrote:
I have to add my new credit card I can't login to my account  I forgot my password
Hi @Luckman
Did you try resetting your password
Highlighted
Moderator
Hi Bball4life,
If you need further help, you can register a ticket through SIMon, our virutal assistant and we will take a look into your situation!
Regards,
Ciprian
PM Mod Team.
Highlighted
"We have sent you an email that will outline how you can change your login and password"
it says all the times nothing received my email box
Highlighted
Still I can't login to my account
Highlighted
Just in case, did you check your junk folder.
What have you tried? Forgot password? Support ticket?
Highlighted
My password is not working, neither my security answer.. I need an add-on for the U.S.
Highlighted
As reset isn't working, you'll need to open a ticket. Click the question mark and type: talk to rep.
Highlighted
@Rabia1703While you wait for the moderator you can also try using 611 to purchas the roaming add on (make sure you have added enough balance to your account before you purchase).. follow the menu from this link https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
created by @z10user4
Highlighted
 @Moderator_Team I need your help to reset my account password. I did not receive the reset link.
Can't send you private messages as the website loads an error when I am doing that.
account
Thanks
edited by computergeek541: e-mail address removed
Highlighted
account
Thanks
Hi @b0gdan. You can send them direct message at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Cheers
