Reset password link expired after 40 mins?
k1mm3r
I need to reset my password on my account, and when i finally got the email and clicked the link, it said that the link was expired. Only 40 mins went by since I received the email and then clicked on the link. Help!
k1mm3r
Oh ok. Weird that i used it within an hr the first time and it didn't work, but if i request it again, it might. Either way I got a response from my message. thanks again
@k1mm3rwrote:
Thank you! I'm doing that now.
BTW the link still didn't work
Not the same link. I meant to say that try requesting the link again. If you get the email within an hour, the link should be valid and allow you to change your password.
k1mm3r
NDesai
@k1mm3r Yes, it expires around an hour. Give it a try again and you might just get lucky. If not, you can send a private message to the Moderator_Team with your account info.
