Request Password Error
brenchu224
Hello,
I tried resetting my pasword today, and thank goodness I didn't delete my old e-mail account yet. For some reason, PM is still sending my reset password e-mails to my old e-mail despite changing the username. Is there a way to change the associated e-mail that I overlooked?
Thanks!
PAULRANG18
Best to contact a moderator for this common issue by clicking ?, bottom right, and follow instructions.
totalUser
Hi @brenchu224
When you change email you only change login not the actual email that can only be done by moderators. Please contact them
Thanks
ChuckYeah
You can change your email on file, but your account will always be attached to your original email address. I'd recommend you don't close it just in case.
@brenchu224 might be worth messaging @CS_Agent to see if you're emails can be set to your new address for future situations.
@brenchu224 wrote:
Hello,
Thanks!
After initial set up, the only way to change the email address on your account is to ask the moderators. It's like on activation it splits off and uses your email address for your login and uses the email address as your account key. After that you can only change the login.
