Relock out
Twin71231
I don't member my securty question or my password I have brain damage can I get them reset
@Twin71231  Now that you have access to your account again take the time to write down your password, pin #, and security question and answer and put it in a safe place. This way you will have a back up if you forget the info again.
will13am
pop@Twin71231 , you are going to need moderator team support for this.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
mimmo
You need to contact moderators using the question mark on the bottom of the screeen.  Type contact moderator or contact human  And follow the prompts till you get to a Submit a ticket form.
