10-21-2017 04:41 PM - edited 01-04-2022 02:47 PM
When I got the public mobile, I had add-on for 200 min long distance.
and I received msg from public mobile. I have only 10 min left for long distance, so
I paid $15.75 for 400 min long distance add-on last July 27 by credit card but I realized
I can not use it right now. also I can not see 400 min long distance add-on on my account.
where is my money gone?
10-21-2017 04:49 PM - edited 10-21-2017 04:50 PM
Purchasing an add-on is a two step process. When you try purchasing, the payment goes to available balance. When you purchase it again, it uses the payment from your balance.
So, if you only tried purchasing once, likely the balance was added to your available balance. In between then and now, your plan probably renewed and so the balance was probably used up. The payment history will show what exactly happened to that payment you made in July.
10-21-2017 04:48 PM
Remember buying the add-on is a two step process
1) putting funds into your account so they are available
2) then purchasing the add-on
If you've done this, then you will need the assistance of a moderator to look into the issue for you.
Send a private message to @CS_Agent, include your following info:
- account number
- phone number
- a brief description of what has happened and when...
…and they will be able to look into it for you.
Click the link for an explanation on how to private message the moderators: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
