09-09-2020 04:24 PM - edited 01-05-2022 01:09 PM
I can sign into my account and when try resetting the password it errors out with a message.
Want to find out if I owe any $ as my CC changed previously.
09-09-2020 05:12 PM
@rakeshsca wrote:I can sign into my account and when try resetting the password it errors out with a message.
Hi @rakeshsca you might want to read this thread https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/change-credit-card/m-p/583329... . Come back and tell us if it solved your issues.
As to the amount of money you owe, Public Mobile plans are prepaid so you don't owe anything. But if you want to continue your present plan, you pay the same amount on your next renewal date. I hope this is helpful. Good luck! 😊
09-09-2020 04:53 PM
If you phone is not working and your autopay cc expired, you can purchase PM topup voucher at Shell gas station to add fund to your account and call 611 from your phone to pay and reactivate your account ASAP. Then get moderator to fix your login.
If your phone is still working and have a few days before your next renewal date, you can contact moderator to fix you password issue.
09-09-2020 04:37 PM
@rakeshsca to get back into your self service account. Contact the moderators and ask them for a temporary password to your self service account. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
09-09-2020 04:26 PM
Calling 611 will give you your balance. But there's no owing money here. What you've paid for will simply stop. Then you pay to renew.
