Reply
Highlighted
Puk and sim code
Need to enter PUK code
Highlighted
Re: Puk and sim code
What exact message is the phone showing?
Highlighted
Here is an explaination by one if the Oracles, Luddite.
SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
  • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
  • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
  • Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted by submitting a ticket at: https://publicmobile.ca.ada.support/chat/
  • Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
Highlighted
It runs me through a cycle of ... enter sim pin, then enter 8 digit puk code , then reset phone pin twice and after processing sim puk phone codes the cycle continues and no progress is made
Highlighted
@Public86 try entering the default sim pin  1234
Highlighted
Did you read the post from Triguy?
Were you able to tell us exactly what the phone says?
Be careful trying a bunch of times as you may just ruin the SIM anyway.
Do you remember if you had set a SIM PIN once upon a time thinking you were being all secure and all?
What is the make/model/submodel of the phone?
