Problem with promotion code
Sahkahnah
When i try to use the promotion code pmoctober1 on the 60$ plan to get the 12.5gb  it tells me the codes invalid.
Also how do i reset my call in pin number?
Sahkahnah
Yea i was thank you. .... i got  a crack in my screen with 2. 1/4 pixel lines   was missing 2gb
Where are these codes coming from?
will13am
@Sahkahnah, I believe your are missing a 2 at the end.  The code you mentioned is incorrect.
@Sahkahnah I'm not sure if all caps are required, but double check that code.
