Problem with making call
Salimcanada
How can I contact moderator since I have problems since yesterday. Can’t make any call even though I have provinces wide calling asking for every call is long distance & asking for add on. I can’t even make a call at home.
10 REPLIES 10
srlawren
@Llyr wrote:
You can contact the moderator through the following link
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
@Llyr sure, they could.  However, the last reply in this thread prior to yours was 1) the original poster replying that things were working now, and 2) dated last November--so even if they hadn't already told us it's working, you could safely assume they had either resolved it or moved on.  There's no need to offer suggestions to an 8-month old problem.
Llyr
Salimcanada
It’s just started working now.
srlawren
EVERYONE AFFECTED:  I just heard from the moderators that this was an outage and should be resolved now.  Could you please try again?  If still not working, try rebooting your phone and test again
closng
@Nimana123 wrote:
But i  can send texts
Yes, the outage only impacts outgoing calls. Incoming/Outgoing texts are fine, incoming calls are also fine.
Nimana123
bgrewall
Having same problem since yest. Located in GTA
closng
@Nimana123,
Everyone is experiencing the same problem.
Nimana123
I have same problem . Plz help
closng
Hi @Salimcanada,
This is a network wide outage, not just for you. Unfortunately, there is no estimates on when it will be fixed at the moment.
