Reply
Re: Porting from Speakout
Hi there,
I just contacted Speakout and had the new PIN and sent it to the Moderator_Team through private message.
Could you please a look at it.
Thanks
@tetrinh wrote:
Hi there,
Thanks
@tetrinhIf you sent the Moderator_Team a private message with the requested info you just have to wait and they will respond back to you via a private message. Once they do a red dot will appear on top of the envelope icon on this page. Just click on it then click on the subject line and reply if necessary.
Good Luck.
@tetrinh : I also want to point out that you could tag the @Moderator_Team to the thread in addition to sending the private message.
The porting was completely.
Thank you all for your help.
My Porting from speakout finally went through. It took about a dozen messages over severall days with the moderators, some of which was my fault. If you want to do it, the key point is that your speakout account number is your phone number PLUS the 4 digit PIN. At least that is what mine was.
