Reply
Re: Port Number from kodoo
Issue has been resolved. Thanks.
I would like to port in from kodoo to public. Both number are active.
Should start your own thread for visibility. Is your koodo account prepaid, and is it still active?
@draslam Just use the form in your selfserveScreen Shot 2019-06-12 at 10.31.24 AM.png
If you are Koodo Prepaid then send a note to the moderators afterwards.
Click here to do so:  https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/self_serve
HI IAM TRYING PORT MY  NUMBER FROM KODDO
SINCE FROM LAST 3 WEEK STILL NUMBER NOT PORT
MY ACCOUNT NUMBER AND MY PIN EVERY THING CORRECT
STLL MY NUMBER NOT PORTED  CAN U HELP ME PLS THANK YOU
 CAN YOU MESSAGE OR CALL ME ON THIS PUBLIC xxxxxxxxxxxx
IAM TRYING TO PORT  FROM KODDO  xxxxxxxxxxxx TILL I DIN T GET
I CALL KODDO THEY ARE SAYING  THEY RELESE NUMMBER TO PORT
BUT PUBLIC MOBILE  PROVIDER NOT DOING IT PLEASE CAN YOU HELP
edited by computergeek541: personal information removed
@TAHER
Have you already tried to port your number via self service account?
You will need to contact moderator if your port has failed.
Send a private message to moderator through the following link :
It will take 1-2 days to respond.
Also, please remove personal information from public forum.
Was this Koodo prepaid or Koodo postpaid?
If prepaid then you'll need to contact the @Moderator_Team < Click this.
If postpaid then this should have been a simple matter of using the transfer number or change number feature.
