Reply
Port Number from kodoo
Hi,
I'm trying to port my number from kodoo and I keep getting this message:
Your Old Service Provider rejected your transfer request. Common mistakes:
  •   • Account Number doesn’t match Old Service Provider records
  •   • Equipment Serial Number doesn’t match Old Service Provider records
  •   • Security PIN doesn’t match Old Service Provider records
  •   • Alternate Contact Number format (should be 10-digits, no spaces, no dashes)
  •   • Did not check the “I am authorized…” checkbox
    • Please review and correct your entries, and click “Submit”
My kodoo account is still active and working.  I inserted my new PM SIM card in my phone and it seems to work fine. I can make calls and send and receive texts.
I called kodoo and they said there is no problem on thier end. I should contact PM and get help.
So here I am.
Help, please.
Re: Port Number from kodoo
hi..
you would have to send a private message to one of the moderators....details on how to do that can be found here:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/All-you-need-to-know-about-our-Communit...
if you try to port koodo post pay service details on how to do that can also be found in this forum..
if you try to port koodo pre-paid you will need a moderator assistance
cheers
Wa
Hello Thanks to post a thread so community can help you. Just to sort out the things to help in a better way. You mean your both sims aare working fine, and you want to port your number from Koodo to Public Mobile is it right??
Hi,
Definitely contact them via private email.
Send an email using the "Get Help" Menu
Follow the menu
good luck
Read this post, follow the instructionon what information to include and how to send a private message.
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
If you want to try the port again, - Tick the I am authorized box first, only use the account #, do not use IMEI, do not use PIN and use an alternate phone number that is not the number you are trying to port.
Yes, that is right.
Wa
Call Telus ask them to send a request for port out your number to koodo
jib
I'm trying to transfer my old phone number over from Koodo. I keep getting that my Old Service Provider rejected the transfer. I'm 100% sure all of my info is correct. What do I do?
Tags (1)
Retraité / Retired
Hey @jib
Sorry to hear about this,
Can you please send me a private message with
-Public Mobile SIM card #
-The phone # you are porting
-Account # with your old provider
Thanks,
Shazia
