Reply
Plan renewal
Hi I can't renew my plan, my credit card had a possible fraud alert so that card was cancelled and now I have a new card but it will not accept my new card when I fill in the new credit card details, help please, i need phone, I'am on auto pay
GR
Re: Plan renewal
When Is your plan due? If it's only in a few days you can go buy a voucher at alot of retailers and put it on your account until you have the credit card sorted out!   Also when you put your address for the credit card don't put anything for app number and make sure you put the correct address as is on the card
Re: Plan renewal
You my to have to first remove your old CC number from autopay and then add your new number.
Re: Plan renewal
I just selected replace card because remove said it would cancel my auto-pay all together. I could remove my old card and start a new auto pay plan, will my rewards from auto-pay be honored? Thanks
Re: Plan renewal
@Felixbthe1
Website is finicky.
Trying a different webbrowser, clearing cache or incognito mode.  Chrome incongito works well.
Make sure that the billing address is exactly the same as your credit card billing address.
Re: Plan renewal
I guess it was due today cause i gotta no service
Re: Plan renewal
Thanks, will try your suggestions
Re: Plan renewal
Auto pay will be honored when new CC card number entered and old CC removed
Re: Plan renewal
@Felixbthe1 If the new card was a replacement from the same bank then replace card was the correct choice. Sounds like the PM system triggered a security lock on your account so it must be cleared by the moderator. Best to contact them with updated info and they will make the change for you. In the meantime a voucher or a top-up is the way to go to get up and running.
Re: Plan renewal
Still cannot renew my plan with my new credit card, does anyone have a link to a moderator, thank you.
