Plan partially Expired
mikasik
I’ve seen couple posts with a similar issue, I can make calls as I have banked minutes but can’t seem to receive them.  I can access voice mail.
@mikasik
@mikasik wrote:
Thanks everyone I found the recently online list and messaged the first one I saw.  Cheers and thanks for your help!
Hopefully, that moderator will respond.  The best way is to submit ticket to moderator_team as described above (instead of individual moderator).  Likely faster response time.
mikasik
You can try to message them directly but this might in fact be a slower way:
Maybe you message them first and open ticket as well,
https://widget.telus.tiia.ai/publicmobile/publicmobile.html, then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
The answer time varies, sometime they reply as quick as 2 hours.:
@mikasik
Maybe try rebooting your phone.  Network reset of phone.
Otherwise, to contact moderator
To contact moderator via 2 methods:
  1. Ticketing system - faster response time
Click on the chat bubble icon on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
or
2 Send a private message to moderator through the following link :
mikasik
Thanks I’m just waiting to receive an important phone call..
is there a list of moderators anywhere I can’t seem to easily find them.
thanks
 @mikasik : I think even older provincial plans were affected by a poorly executed revival of provincial plans recently...now dropped. You'll need to contact the moderators.
I think that Expired can be ignored.
