Phone not activated as phone number not able to be ported now what?
gptpisapu
Phone not activated as phone number not able to be ported now what? phone number associated is ******************
@gptpisapu  Please edit out your phone number.
    Are you trying to port your number from koodo prepaid or pc mobility prepaid? A moderator is required to "port " a number from these two providers as they dont actually get ported but switch accounts from the same prepaid system they share ith public mobile. Open a ticket as per the instructions provided by @dabr .
     Take a temporary number as suggested and wait for moderator help with your porting request. Wait times have increased significantly lately for some reason?!! It could take up to 48 hrs for a response. Keep an eye on the envelope icon next to your avatar at the top right corner of the screen for a little number to pop up indicating a message from the moderators. Responding promptly to messages will speed up service times.
Triguy
If you are having trouble with your services, the next step is to contact a moderator. Here is the link to create a ticket through SIMon:
https://www.publicmobile.ca/en/bc/get-help ->Click on Chat with Simon on the line "ask me something" write "moderator" -> then click on "account specific question" -> afterward click on "no, I want a human" -> finally you will see an answer "submit a ticket Click me!"
dabr
@gptpisapu wrote:
Phone not activated as phone number not able to be ported now what? phone number associated is 506xxxxx
@gptpisapu  Please use the 3 dots top right of your post and delete your phone number as you are on a public forum.
Was your old account still active when you tried to port?  That is one of the requirements.
Anyway you need to submit a ticket to moderatos via SIMon here: https://publicmobile.ca.ada.support/chat/
Type in your issue, select contact us/moderators, then submit ticket when these options appear and follow the rest of the prompts to finish.
If you have problems messaging through SIMon, try private messaging Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Edit:  @gptpisapu  You can get a temporary PM number until you can port in your previous number too.  Just log into your account and select a number from the Change Number option (right hand side of the overview page), or the Plans/Add-ons tab (top of page).
Also can you try rebooting your phone.  Another to try is power off your phone, remove SIM, wait several mins and re-insert SIM and restart your phone.
