Phone calls and texting not working
jess4buck
I changed my plan from the 45$ to the 21$ and would like to know when I will get my service back on
23 REPLIES 23
srlawren
@CellAid wrote:
Did you pick the $20 data only plan by chance?  There are only two $20 plans that I'm aware of, data only and calling only.
@CellAid no, and it has been resolved now
CellAid
Ok thanks to let us know...and don't forget to click on the good answer ...ACCEPTED AS SOLUTION...It will help other to find the solution...Have a nice day @jess4buck
jess4buck
Marking it as lost and then found
jess4buck
Awesome it worked!
Happy for you! What was the solution then @jess4buck??
@jess4buck wrote:
I just got the talk and text plan no data too broke this month lol for data
We joke...as I'm sure it was a typo. You mean $25 right? Or do you have a couple referrals or have you been here a couple years along with maybe autopay?
srlawren
@jess4buck glad to hear it!  Sometimes when changing plans, the system gets a bit confused.  Reporting lost suspends your service, and then marking it found makes the system go back and re-allocate your talk and text (and if you had it, data) to reactivate them.  It seems to work most of the time when this happens.
jess4buck
jess4buck
It worked thank you
jess4buck
Thank you all it worked!!
srlawren
@jess4buck wrote:
Here goes nothing lol thank you
@jess4buck any luck?
If you tried all the things and your account is active and nothing happen...you will need to ask for help from the moderator...here..
and explain what happened... You will wait few minutes or 2 days...but you will have help for your account...
@RobertQc wrote:
@jess4buckThere is an in market $21 plan?
Thank you! I was reading this thread thinking ...um...what $21 plan?
RobertQc
jess4buck
Sharry19
@jess4buck It's wasn't inactive more than 90 days ?
missorange
it seems like you did immediate plan change. When you do renew your plan in future date, the service should renew itself. if you change plan immediately, and the service not renew properly, you may need to try lost phone funtion.
@jess4buck, If your self serve shows your plan as now Active, you could try the lost/found phone trick.  Report your phone lost/stolen, wait a few minutes, then report it as found.  Then restart your phone.  This sometimes helps kick start things...
jess4buck
Lol that scares me too much to try
jess4buck
I changed it when it was an inactive account
Yes I turned it off and started it again
Sharry19
@jess4buck Just wondering when did you change the plan ?
Did you select change plan now or Next Renewal date ?
Try to click on lost/stolen phone & then after 5 mintues click found phone, sometimes it works
**** Please note: I am not a Moderator ****
stonechucker
@jess4buck, was this an immediate change, or scheduled for your next renewal?
Was your plan active, or inactive (expired) at the time?
Have you attempted to restart your phone (turn it off, then back on)?
