Payment Voucher Problems
Benjamin318
I bought a payment voucher at shoppers drug mart today and it wont seem to work, ive tried the voucher number multiple times but to no avail. I contacted the shoppers that i got it from and they wont help me. the message i get is as follows:
Unfortunately, Voucher #(myvouchernumber) could not be added. Please verify the Voucher and try again.
Any ideas?
8 REPLIES 8
havswiss
itried the *611 number and it still did not work
@seeseepowpow wrote:
 I had a similar voucher problem today using self-serve (voucher #(myvouchernumber) could not be added. Please verify the Voucher and try again). After reading this thread, I used *611 and was able to add the amount instantly.
Thanks for sharing your solution!Smiley Happy
seeseepowpow
Benjamin318
thanks much, 611 worked for me!
sandpublic
Any ideas?
Try the Lost/Stolen trick by logging into your account select lost/Stolen wait a couple of minutes and then select Lost/Stolen again then try the voucher to see if it works.
hairbag1
Any ideas?
 Have you tried dialing *611.
Any ideas?
There's a strong possibility that they have a delay in flowing the voucher existence through to PM. Ask them if it's immediate or whether they reconcile their terminal some time later.
But try again in a little while. If tonight is your renewal night then try to do it before things can get a little messed up after 7pm ET.
Lieux
Any ideas?
I read that some voucher can take up to 2 days sometimes to be activated..is it the case you have to wait a bit longer? And the number is with 12 characters?
