Reply
Password
I'm locked out of my account, I need help resetting my password.
Thanks
Re: Password
@Mcmack Try resetting your password using the Chrome browser in incognito mode. If that doesn't work you will need to contact the moderators, you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Re: Password
i have found some places if you wait a day or some places state a couple hours, if you find out from moderator how long have to wait for it to be unlocked, you may be able to log in and as well i think there is a forgot password link somewhere underneath the login buttong and if click on that will ask for your email on your account and will send you a link so can click on that to reset it.
