Password reset
GACB
Please help! I got locked out of my account and need to reset my password
popping
@GACB wrote:
Thanks! I already tried that but it won’t work
How long did you wait for the reset email from PM?
It took about 5 minutes for me to receive my PM reset email couple days ago.
@GACB choose the second option and send a private message, Simon will not allow you to create a ticket because you need to login to your self serve account to verify
or click here
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Triguy
You would need to submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
GACB
dabr
Did you try password reset?  Try that first as you should get a reset email notice within a couple of minutes.
Otherwise submit a ticket to moderators via SIMon chatbot ? mark bottom right of your screen.
Edit:  Another thing too many attempts with an incorrect password will lock you out for a short while as well, so waiting a few mins to retry will work too as long as you know the correct password.
Triguy
You can use the forgot password option.
https://selfserve.publicmobile.ca/forgot-password/
