Need to recover my user name and password
Bbamathy
Forget my user I'd and password
Try to recover no one help in public mobile side. I send private message including my number and pin still no answer from moderators team.
Need to get my user id
8 REPLIES 8
@ARNOTT
You tried the Reset Password link?
or you can open ticket with PM support and have them to reset password for you.  After you got it reset, you can then login my account and reset PIN yourself
to reset password, please open ticket with PM support
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
ARNOTT
Hi
I for get my password and PIN, I need help
If you don't remember which email you used and you don't have too many. Look for the welcome email from pm. It will only be in one account.
Bbamathy
Yes. But I forget which one i used . I when i used one of my Yahoo accounts, it shows now " login disabled"
Message
I don't know what to do next
geopublic
@Bbamathy  If you never setup your selfserve account then you need to register.Click here to register your selfserve account.
shskr
After entering your email as user ID, try the forgot password feature to update/change password to access your account.
geopublic
@Bbamathy Your username is the email you used when you activated your account. Did you try that?
will13am
@Bbamathy, moderator team response time can range from a few hours to 48 hours.  Stay patient.
