Reply
Need a new pin
Hi I need a new pin for my phone as my SIM card is locked.
Re: Need a new pin
@Leeesa53  it's probably asking for a network unlock code. That means your phone is locked you need to talk to your previous provider to get that code.
Re: Need a new pin
You would need a puk code which usually has to unlocked by your previous provider.  If you have a Samsung phone then they could provide one if you contact them.
Re: Need a new pin
@Leeesa53
Some good info from cappaj from his S7 and the messages he got.
"SIM network PIN blocked. Enter SIM network PUK."
- This is asking for Samsung's "master code" - I got this after entering the wrong code for the message below too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN"
- This is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you easy peasy. If you enter this incorrectly too many times, you'll get the error message above.
