My phone isn't working
Zally
Local calls won't go through. I'm getting a message saying that the number I'm calling is long distance. It's not working for any numbers. Please help!
darlicious
Are you saying you can't make any calls? Are you on the $10 or $15 plan? If so log into your account and check your plan in the overview page. Do you have your outgoing call minutes listed. If not...youve used them all up. Buy the $5/500 min add on. These will roll over til used. Good insurance for when you exceed your plan minutes.
Which message are you getting? Is it the one about how a call is long distance and that there could be charges or does it say something about not having a long distance add-on. The first type of message can be ignored.
clexxi
Try putting a 1 in front of the number you are calling. Eliminates that message warning it a long distance call when in fact it isn’t.
dabr
You can add +1 in front of the numbers you are calling, but that is also an pre-recorded message that seems to get played.  Wait for the message to end and your call should still go through.
