My account got blocked, what should I do. I would like to reset other email address
jesseyin0109
7 REPLIES 7
 you might want to wait an hour before trying.  There is a temp lock that will kicks in for 1 hour if you tried too many times.
if you just not sure which email address used, you might want to use the Forgot Password button and try with all the email addresses you have.
If you are certain you need to change password or email address, you will have to open a ticket with Mod.  Use the bubble on the lower right..
(uodate:  sorry  just notice that this is an old thread...)
melissa813
You have to get in contact with a modarator
Nikita
Just clear your cache. It will be fine. Better yet try  from a different computer and this time say u forgot  password 🙂 good luck
@jesseyin0109
You do have active service? Your not suspended and gone past 90 days?
if you have just one browser to used Wait one hour
and Clear cache and cookies,
and if you can try it from different browser is better
Good Luck
HALIMACS
Thereafter... to change email address (login username to PM'S self serve site), you'll need moderator assistance.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator, then select contact us, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
HALIMACS
@jesseyin0109
Do this:
  • Wait one hour
  • Clear cache and cookies
  • Open incognito tab
  • Try again
