My Account
DianeJulian1
P.M. doesn't recognize my email or ph # to sign into my account.
I can dial 611 and get my account balance.
Not sure what I'm doing wrong.
DM100watch
Thanks hairbag1 it is working now....😀
@DM100watch wrote:
There seems to be a self-serve outage.  I can't get to the self-serve portal either, and others are reporting similar problems.  Hopefully it will be resolved soon.  Do it by phone 611 with your PIN if you can't wait.
@DM100watch...try using incognito mode / private mode. Otherwise just wait until current issue is resolved. These outages don't usually last very long.
Did you activate at a store or at home?  If you activated at a store, I'm assuming that you're trying to create the self serve account at Public Mobile - Register ?
If you're still having trouble, you'll need to open a ticket by going to: https://publicmobile.ca/chatbot
DM100watch
