Reply
Re: Made a payment...still no service
Could try manual load of $1 to account as suggested above.  Or try the lost/stolen trick again later on.
Otherwise, you might be stuck waiting for moderators.  The wait times have been about 2-3 days unfortunately....
not sure what ur asking, but ill shoot blind. If u made a payment, give it some time, it should work by now. U might have to reset by doing the fabled lost phone trick. As for long distance. Make sure its enabled.
Did you select to change plans immediatly or when your next cycle starts?
You could try turning your phone off, enter "reset" mode (but don't reset it) select "clear cache" and reboot your phone.
Did you check that your phone is not in airplane mode?
You should consider getting a new sim card at this point.
