Lost SIM card before I could create a account
lilroman
I did the same thing? Would like to know how to cancel the SIM card?
lilroman
Thank you!
Alex888
If you didn't activate the SIM card then you don't need to cancel it. Just buy a replacement and register the new one for an account.
NDesai
@lilroman  You posted in an old topic, i have moved your post for better visiblity.
You cannot get refund as the service is prepaid. All you can do it enable lost/stolen feature from your self-serve account. if you do not have self-serve account access, then you will need to send a private message to the Moderator_Team and they will get in touch with you shortly. Once you get a new sim card, you can change your sim number directly from your self-serve account.
