Reply
Highlighted
Log In Fail
I cannot log into my self serve account.
Accepted Solutions
Highlighted
Re: Log In Fail
First, wait about an hour before trying again as you might have temporarily locked yourself out by trying too many times.
Your password can be reset by going to https://selfserve.publicmobile.ca/forgot-password/ .
If that doesn't work, you'll need to open a ticket at https://publicmobile.ca.ada.support/chat .
All Replies
Highlighted
Re: Log In Fail
Highlighted
Re: Log In Fail
@haileefernn Try resetting your password from this link: https://selfserve.publicmobile.ca/forgot-password/
If you are unable to reset your password, please contact the moderator team.
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
_________________________________________________________________________
If you need to contact PM, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
Highlighted
Data Ran Out
I would like to upgrade my plan and add more data onto my phone. However, I cannot log into my self serve account to do so. I cannot remember any of my log in information.
Highlighted
Re: Log In Fail
When I try resetting my password, I get a notification that my username does not match up. When I try creating an account, it says my phone number is already registered with an account.
Highlighted
Re: Log In Fail
You'll need to follow the instructions provided earlier for contacting a moderator.
As for upgrading your plan, an immediate plan change would be required if you want data to start working again. However, you'll want to remember that there will be no refund of the unused days of the old plan, and if you ever decide to swtich back to your old plan, it might not be available in the future. The other option would be to purchase a data add-on. 1GB can be purchased for $15.
Highlighted
Re: Log In Fail
@haileefernn you can contact customer support here
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
Highlighted
Re: Log In Fail
but to get a ticket-- you have to remember your account number, which i forgot.
what do i do, if i forget my email username passwrd account number???? i cannot log in or get a ticket.
Highlighted
Re: Log In Fail
Account number is not needed to open a ticket. If you do not know your self serve login, the 4 digit PIN is enough to confirm for the moderators that the account is yours.
Highlighted
Re: Log In Fail
my memory is horrendous. i don't remember my pin. it's been so many years that i ever used it
