Locked out
jessica563
I am locked out of self-serve. Password reset link does not work. When I chat with Simon he suggests that I submit a ticket. To do this I am asked to login, which I cannot do. Any tips?
@darlicious wrote:
@Triguy wrote:
Try using a different browser and incognito mode.  Also clear your cache and cookies then reboot.  If you need to submit a ticket then click on the question mark on the bottom right.
Oh right...forgot the reboot.
I don't think a reboot is required for this. It's just the browser...not the computer. Never hurts to reboot of course...it just takes time.
Triguy
darlicious
Also you can also wait one hour...it might reset because you tried too many times. Next time clear your browser/cache use secret/incognito mode and try again.
@darlicious wrote:
If I remember correctly you can log in using your community profile and password.
Be sure to include any relevant info that you can remember ....email , pin code? Phone number etc...write down the ref# so you can follow up or cancel if your issue is solved before you talk to a mod.
darlicious
