Locked out other account
Griff
I have an account under another email of mine and forgot the password, and locked out the account attempting to reset it.
BlueB
@Griff
Depending on what you need to do, you can consider calling 611 in the meantime as well (eg. for voucher top-up).  I'm guessing you'll probably need more done than that, but just making a small suggestion!  🙂
Griff
Thanks Dunman,
I didn't realize the lock would time out after an hour. I only locked the account because it asks for a security question just to do the password reset.
Dunkman
@Griff
Maybe wait one hour and try again.  You get locked out after about 5 tries.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If that does not work, then you will need to contact moderator. Click on chat icon on right lower corner of website.  Type: unable to login.  Follow prompts to submit ticket for moderator help.
