Reply
Koodo port to public
Hi im trying to port my Koodo number to my public account but it says my number is not eligible in self serve.
What do I do?
Thank you
Re: Koodo port to public
Is it prepaid? If so you have to contact moderators to do port for you.Simon.JPG
@2phones , Koodo prepaid and PC Mobile postpaid customers need to seek moderator team assistance for number porting.  The moderator team can be reached via private message using using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team.  Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions.  Refer to the following knowledge base article for additional information on the moderator team.
No it's not prepaid.
Would it be because I have a small tab left on the Koodo side?
@2phones Is your account with Koodo active? You can't port a number if the account is closed.
Yes it is active still.
@2phones
PM web interface does not handle session state very well.
Restart your browser after getting error and try to port your Koodo postpaid number again.
Restarting the browser does not seem to change the outcome.
If the email addresses are the same for the Koodo and public accounts would that be the issue?
@2phones  It shouldn't be. I used the same email for Koodo prepaid and Public without any issues.
Weird,
I have three 3 lines with Koodo and only one out of the 3 that is registered to a different email and doesn't have a tab is eligible.
So I wonder...
