Is self serve down?
shawnie_boy
Doesn’t seem like webpage works?
First check if browsing other webpages is also very slow on your device.
If it is, then reboot your device and/or router/modem if you are connected to one.
If everything else working fine and its just PM webpage then there may be more traffic on the page or slow server issues.
I was having problems logging into the community page last night 😞
When I have had this issue rebooting the affected device usually resolved it.
mimmo
@collin1215 wrote:
the community is a little slow for me. It keeps timing out. Same for the self serve
Too many people trying to join PM to take advantage of the new pricing??? I guess it's time to raise the plan costs (joking)
collin1215
mimmo
I just logged in. so no issues that i can see. try a different device or different wifi?
TaylorJW
Self serve is online for me. Try CTRL+F5 to clear cache and refresh.
