09-04-2019 04:40 PM - edited 01-05-2022 06:51 AM
Hello,
I used to be able to send messages by imessages no problem when I had a virgin mobile sim card. Now with public mobile I am having problems. For imessages it is saying that there was an error and not able to connect for imessages.
09-04-2019 08:09 PM
@shanmorrisBack up your phone.
Go under Settings -> Click on your AppleID and Sign out.
Go under Settings -> Messages -> Turn off iMessages
Go under Settings -> General -> Reset.. Reset Network Settings.. do note you will loose previously saved wifi passwords and bluetooth connection doing that.
Once that has been reset, make sure you have a wifi connection and login your AppleID. Start a browser to make sure you have internet access, then restart your iMessages.
Try sending a message.
09-04-2019 08:01 PM
@shanmorris wrote:Hello,
Did you port your number over to Public Mobile or did you use a new number?
If you used a new number, you have to reconfigure your imessage as I know it as it sometimes reverts to your email or something like that
09-04-2019 05:20 PM
Have you only recently ported from another cell network. Is your phone working on PM network now ? If you just ported today, maybe the port process hasn't yet completed.
09-04-2019 04:55 PM
Another thread on here the person said they took out sim card. Shut down phone..restarted and it worked for them might want to try that.
09-04-2019 04:53 PM
@shanmorris hi are you using the same number as you had at virgin? if not I know that your apple id settings have to be updated with your new phone number it screwed things up for me
09-04-2019 04:51 PM
I phone 8
09-04-2019 04:49 PM
Does data work at all on your phone? Like if you try to google something?
Check APN settings on your phone they should be this.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
09-04-2019 04:47 PM
Cycle iMessage off and on again. Then reboot phone. Which iPhone you using ?
09-04-2019 04:46 PM
Already did that and no luck.
09-04-2019 04:45 PM
Already did that.
09-04-2019 04:43 PM
@shanmorris check your settings for iMessage,, turn them off and back on and then restart your phone
